RB211, it's not a point of contention as I see it. I just don't have a follower of any sort. I think the lathe threading ion this skinny 3/8 rod 18" long is a good idea...I just am unable to do it at the moment so I'm trying to find another way to do it. And I think I have another way to do it under power now.
By using a different stock I could open the die a couple thousandths and that made all the difference in the world in the forces required to spin the rod through the hand held stock. So, using the setup pictured, the keyed chuck held the rod securely without horsing it down too hard and it took about a minute and half to turn the 9 inches of left hand thread. Lots of oil, chips falling out of the die into a bucket on the floor, and a vice held start before putting it to power works like a charm. The heat build up was significant but not untouchable. I'm impressed with the performance of that ALPs die.
A test fit revealed that the thread is too snug, so I'll repeat the process with the die held to normal size. The hold up to doing that is the old stock that has three set screws to hold the die are all stripped out. The new stock has only one set screw and it's metric, so I'm setting up to drill and tap two more setscrews to match the original set screw. Then it should work to hold the die at finish size.
DanK
DanK
