Thanks, I did get one to move. It was tight even with the screw all the way out and PB blaster. The other one is not budging. I will soak it a few days.
I did get a large chuck in the pile of stuff that came with the 9A. It will not fit the 9" at all but spun right on the Boxford. I probably will not use it a lot but there have been times I could have used a bigger 4 jaw. I have had pretty good luck taking rust off chucks with evapo rust. I will see how clean I can get this one.
