I have had a full metric CUD Boxford lathe for about ten years now. Not sure how it ended up in the USA, but it's done good by me. I have wished for the power cross slide and a way to change feed speeds without breaking out the wrenches, almost every time I use it. Its a hassle to do the change gears and I never have touched the bag of gears to change feeds. It's set at a fairly slow feed speed and I just make do or hand feed it if I am in a hurry. I have tried to locate MKIII parts in the UK to do a conversion but it seems I almost have to buy a lathe from the UK and ship it as a lot of other people are looking for the same parts. I contacted Lathes UK about parts ten years ago and their advice was to start over with another lathe rather than to try the conversion. Here in Oregon USA the main industry was lumber for many years, I think now that's transitioned to pot. Not a lot of industries that use lathes and then retire them, so decent lathes don't show up local often like in other parts of the USA. Most of the time I lose out if it's any good as they go fast. After loosing out on a Heavy 10 last year by waiting to buy because it was not in great shape I decided to just buy next time and sort the details later.
So yesterday a more worn but usable south bend 9A cabinet model showed up with a three phase motor. I bought it 1 hour of listing, thinking it was the likely replacement for my Boxford. The 9A is about the same machine, all my tooling and chucks cross over. but looking at the specs, it's not. From what I can tell the Boxford maximum spindle speed is close to twice that of the South Bend, The Boxford has a roller bearing headstock and a lot of refinements, large dials, quicker head and tail stock use, t-slot cross slide, a splash shield on the cabinet and 1" taller height. So now I am having second thoughts. Yes the gearbox and power cross slide would be nice but it's a toss up. I did not pay too much for the South Bend and can get my money back out plus a little more for the trouble and fuel to haul it home. It does have the tail stock, it just was sitting on the floor. My CUD didn't look so hot when I got it either but it cleaned up nice. Its got a lot less wear on it though.
I have gotten a lot of good advice off the forums. Right now it's not so clear what one to keep.
