I spotted this rotary table on Craigs list this afternoon and thought someone of you in the area might be looking for something like it. It's way too big for my table top mill. It is located about 110 miles north up the coast from me. The price seems about right. Here is a link for it. https://oregoncoast.craigslist.org/t...386214833.html
Rotary table
Sounds like a cheapie if they couldn't afford left handed screws. I'm sorry but that is just a mark of cheapness. Encountered that on a horrible freight DP vise. Just one of the axis. Criminal enough to deserve the dumpster. Pawned it off to some other schmuck for 70% of new cost.
This appears to be for drill press use as well. Why would you eve have slides below the rotary axis on a mill. That's just two more places to remove rigidity and do no favors. Slides on TOP make a small amount of sense. I could have used that yesterday finishing up a project that took me ages to bump in to within a thou or so. I'd say then you can cut in angled planes, but normally you can do that anyway just by rotating it. So it really doesn't make much sense to have axis on a rotary table at all.
Not a fan. Just give me a heavy 12 and 8". But a deal for someone I'm sure.
Originally posted by The Metal Butcher View PostSounds like a cheapie if they couldn't afford left handed screws. I'm sorry but that is just a mark of cheapness. Encountered that on a horrible freight DP vise. Just one of the axis. Criminal enough to deserve the dumpster. Pawned it off to some other schmuck for 70% of new cost.
Looking at it, it appears to have left hand Acme screws. Looks like just a choice of which way is considered to be the "+" direction. The way it is, rotating the screws clockwise would move the table so that the fixed location drill, or cutter would be closer to the back of the part, as mounted.
As for the slides, it's also a choice. On top, they really just let you center the part more easily. On the bottom, they let you do multiple circles of "features", by moving the whole rotary part. I've seen them both ways, and there are as many points to having them on the bottom as on the top. The way it is set up is the same as most slotters, which commonly have a rotary table on top of x and y slides.
With it tilting as well, that adds another capability, although the usefulness of the slides is reduced a lot if tilted. But setting at any arbitrary angle to drill or maybe mill, that has uses, and most rotary tables only do a 90 degree angle.
4357 2773 5150 9120 9135 8645 1007 1190 2133 9120 5942
"There's no pleasing these serpents"......Lewis Carroll
- Likes 1
If I didn't already have a old Atlas XY cross slide table on my drill press, I would go buy it. I'll watch it for a while and if it's still there in a week or so, I might drive up the coast and look at it. It does look like well worth the $95. My wife would throw a fit._____________________________________________
Oregon Coast
I found that it was "...custom designed and built..." to be curious. How could that be affordable? Unless it was shop built & then the castings would be an exceptional accomplishment for a DIY'er. Or maybe they're welded up. If shop built, the accuracy could be all over the map. Curious indeed.
- Likes 1
The $1680 of the Palmgren makes this $95 even more attractive.
Originally posted by Bob Engelhardt View Post
JL................
Yes..
It is easy to point out the copy cats.
They will have steel straps along the sides of the tool.
Thats not supposed to be there. JR
