Some work on a TX650.
  • Definitely a labour of love! Nice job so far....
    Ontario, Canada
    • Completed the last job today, fitted the baffles to the mufflers. All that's left to do now is rip the bike apart and repaint, then reassemble. Don't know when though, I like looking at it now it's finished.
      I'll be repainting with the same black, but this time applying an iso free two pack clear over the base colour coat on some selected parts: tank, seat, guards and maybe a few other bits.
      When resprayed and assembled I'll fit tyres and get the the seat covered, don't trust the upholsterers with the seatpan, that's why the two pack iso free clear on the seatpan before getting it covered. I was going to cover it myself, but the Singer has given up the ghost.
      When resprayed and reassembled I park it in the garage and cover it up and go out every now and again, uncover, sit on it, blow through my lips to make some appropriate motor bike noises and dribble down my chin.
      Don't know what I'll do after this, maybe an R65, if there's anything left of my elbows.
      • Completed the last job on the bike today, polished the second exhaust hanger and fitted the baffles to the mufflers. All that's left to do now is rip the bike apart and repaint, then reassemble. Don't know when though, I like looking at it now it's finished.
        When resprayed and reassembled I'll park it in the garage and cover it up and go out every now and again, uncover, sit on it, blow through my lips to make some appropriate motor bike noises and dribble down my chin.
        • Congratulations on a beautiful piece of work! I wish I had the energy and motivation to do such nice work.
          Dan
          • Probably the last startup before tearing it apart again for repainting. Sync was a little out, so I adjusted the idle screws, turning the idle screw a fraction results in a big difference to the manometer. Happily, the mufflers do an excellent job of quieting the beast. https://www.youtube.com/watch?v=zBXAk8sPwMI
            • Purrs like a kitten till the Lake pipes roar!
              Sole proprietor of Acme Buggy Whips Ltd.
              Specialty products for beating dead horses.
              • Sounds and looks beautiful, can hardly wait to see what she looks like in fresh paint and a set of tires to complete the picture.
                Although she looks mighty fine just as she sits there.
                Also nicely made manometer set you have there. Although with your attention to detail I would have been surprised if you hadn't made a set.
                • I thought I’d make one more video before tearing the bike apart. This one deals with carb syncing with a manometer.
                  This manometer has a relatively large body of water, and the vacuum lines are fitted with a .6mm jet. This has the effect of slowing down the movement of water stabilising the readings and making the device extremely accurate. Just a miniscule turn of either idle screw or throttle adjustment screw greatly effects the fluid levels.
                  I have great trouble with my fingers, so you'll notice me changing hands frequently trying to turn the adjustment screws. I also turned the adjustment screws the wrong way a few times, putting the levels out.
                  https://www.youtube.com/watch?v=9-iw8Z2I5o8
                  • This is a new brake divider I machined up to replace the original. The original hoses were rotted, so I replaced them and did away with the two steel tubes that connect the hose to the calliper and the hose from the master cylinder to the divider. Unfortunately, the new hoses have the banjos on the same plain requiring the lower hose to be twisted through 90degrees to connect to the original divider, so I machined a new divider to get around the problem. The lower hose connects at the rear of the divider, as does the brake light switch. The top hose connects to the side of the divider.
                    • You really do nice work! I’m enjoying the build and the thread!
                      • A few hours is all it took - it's just a pile of bits that once was an almost complete bike now, just needed tyres and the seat covered. Going to be a big job polishing all those bits again, any volunteers???
                        A couple of mods on the frame to do: Remove the coil and flasher mounts then repaint along with tank, guards, seat, trees and a few other bits. Not sure what paint to use this time. I used acrylic lacquer last time, but spilt some petrol on the tank and it stained it. Painted heaps of tanks with acrylic lacquer before but never had this problem, either the paint is different or the petrol is. Don't really want to repeat the exercise.
                        • Applied the final coats of acrylic lacquer to the tinwork and some ancillaries this afternoon, didn't come out as clear or as good as I hoped, but acceptable I guess. I'll give it a few more days then sand the tank and spray over with 2k clear. Not the done thing, technically, but plenty do it, so we'll see how it goes.
                          • Painted the tank, seat, guards, headlight and callipers with 2k clearcoat this morning. Unfortunately, I can't wear glasses under the respiration so I couldn't see too clearly - bloody great run on the tank, damn. Couldn't get any non isocyanate free, so just the usual 2K.
                            It's been over 40 years since I used 2k, so I couldn't remember what coverage was like, how much paint I'd need, googled it in various painting forums. 2litres minimum for frame, tank, guards seat, headlight I was advised. Armed with that knowledge, I shyed away from 2k because it would have cost near as damn it to $450/$500.
                            Seems our painting professionals haven' a clue., I mixed up 250mm clear, 125mm catalyst and a little thinners. Got three coats down on tank, guards, seat, headlight and callipers and still had 200mm of mixed paint left.
                            By the look of it, I won't be spending anytime compounding or polishing the paintwork.
                            This pic should give you some idea why painting and, polishing aren't my favourite past times. Scared the crap out of the dog.
