For those interested...
In a past thread I had indicated that I would experiment with common jade and synthetic corundum for use as lathe bits and scraping blades. The following is the results so far.
Common jade - Lathe bits. Pretty much a wash out. Micro-fractures on all materials I tested except for Al. On Al, the jade leaves a visably better finish than HSS and does not weld. I do not have carbide bits that are specifically recommended for Al. so I did not compare carbide.
On Al, the jade holds its edge, with no visible wear for about 12-13 minutes of cutting, then suddenly, the edge wears completely out in a few seconds. Thermal stress?
Common jade - Scraping blade. Refuses to cut. Edge fails on first attempt. Tried several angles between 85 and 95 degrees.
Corundum - Lathe bits. Interesting results. Started the experiment with the corundum ground to the same angles as a common c-2 carbide insert. The corundum would micro-fracture on contact with the work material, then would continue to cut with no measurable wear for as long as my patience held out (about an hour). Work surface finish was terrible, all feeds/speeds. Reduced the relief to 1-2 degrees, tried again. Isolated micro-fractures, similar to what you see with a new carbide bit. Surface finish on work was as bad as I have seen. Kinda of a hacked appearance. NFO In its single crystal state, corundum exhibits directional hardness with respect to its crystal lattice. Usually 9.0 on the MOHS scale, and 9.4 MOHS cross-grain to the lattice. So with difficulty, 9.4 is hard, even for diamond, I cut and polished a new test bit against the grain. Cuts like a champ, very few micro-fractures (same angles as carbide). Surface finish really, really bad on all metals. Now here's the suprise - Plastics... best finish, smoothest cut. Didn't do wood Thrud, but based on your tip, I will.
Corundum - Scraping blade. Ground and polished to 93 degrees. Wears much better than carbide. In fact, I'm still using one of my test blades after 6 hours of scraping. No measurable wear at the macro or micro scale. Very fragile. Made three test blades, lost two to fractures in the first few minutes.
Discussion - The jade was fun, end of experiment. Don't know whats going on with the corundum. Much better than the carbide I have, but still not suitable?? Going to try some more experiments, open to suggestions folks.
[This message has been edited by Fred_Farkle (edited 02-09-2003).]
