Crude live tooling
  • Crude live tooling
    Longitudinal grease grooves in 932 bronze bearing bores 7 1/ 2" long.
    Asked my employer if they had done this job in the past, indeed they had and he finds a right angle die grinder hose clamped to a holder under a bench.
    Chatter City and a slow process but they are only lubricant grooves so are not measured by the customer.
    Crude but effective (-:
    This looks like a classic "do it on the shaper" job.
      The results don't look the least bit crude. Well done.
      It's all mind over matter.
      If you don't mind, it don't matter.
        This assumes having a shaper, I have worked in the business for 30+ years and have NEVER seen a working shaper in a machine shop that was not a simple keyseater.
          did you rough the bore in, cut the grooves and then finish the bore to size? Or finish the bore and then cut the grooves? If the latter, how did you clean up any burrs left by cutting the grooves?
            That had to make an interesting noise. But it obviously worked!
              I last worked in a shop that was not my own hobby shop 40 years ago, and they had a couple of shapers. Mind you, they also had other machine tools that may have already been 100 years old! They were not exactly what you'd call at the leading edge of technology...
                Finish bore then groove, bronze is easily deburred by hand. The customers bore dimension is 4.502"-4.500".
                The groove dimensions are fractional at 1/8" wide by 1/16" deep +- 1/32", 4 grooves evenly spaced so there is a good deal of room for error, eyeballing the scribed lines is more than accurate enough. Did it in a manual lathe using the tail stock to control the feed rate.
                  With the blind end of the groove, that would be a problem for a shaper. To avoid jamming up chips at the end of the stroke, might have to carefully back of the stroke ( move the part , maybe) on successive cuts. Have to give that some thought ???
                  Joe B
                    Joe make that double blind end...single would be ok if you end in the groove.
                    if you mount bushing at an angle you could come in from open end and , end at circular groove .. but cut would be 0 depth on syptart end and full depth on other end..
                    that could maybe work if the turned bushing 180 degrees for 1/2 of the 4 grooves... but not to the specs shown. .
                    be very quick in production.
                    i must apologize, i viewed this a while before I posted, i thougjt in error that there was a circular groove on each end of the straight lines.
                      Annoyingly loud, over ear headphones recommended, I use Marshall headphones connected by bluetooth to a tablet or laptop, small and light weight.
                      Excellent ear protection, however they cost more then $0.00,
                        What did you use for a cutting tool? 1/8” endmill, carbide burr, or ???
                          HSS 1/8" diameter full radius endmill, a 1/8" wide grooving bar for the circumferential groove, the customer drawing does not specify a corner radius.
                            I can see why that die grinder chattered. It's hanging out there quite a ways.
                            Also, wouldn't it have been better to cut spiral grease groove ?? Since your straight grooves are spaced at 90 deg. the only part carrying the load in line with the grooves are the ends where the grooves stop.
                            JL................
                              makes sense, thanks
