More Doall Cutting
I agree with Doozer. Great work TTT. I want a Doall now so I can slice bread and maybe other things.
Originally posted by Tundra Twin Track View Post
BF I will come clean and admit using the over 70yr old Doall is kinda nostalgic for me.Every time I use it I think of the 1000’s of these Vertical Saws that were used in manufacturing & repair shops with operators standing for many hours a day with some doing internal sawing cutting & welding the blade numerous times in one shift.
The pic below is 3/4” plate 24” cut took 16 min.
Well, technique won't 100% get rid of the HAZ.... You can minimize it if you are good, and it definitely does not have to have big goobers hanging from it.
The only part of this I agree with is needing or wanting the practice. If you know how to use a cutting torch correctly then there is very little grinding and clean-up. If I took that piece of steel to my belt grinder and slid it across the table on a 36 grit belt it would look better than a bandsaw cut. TTT had a valid reason for not using the torch. Time for the part to cool down. If I am in a hurry I can cool it with air or with my kool mister. Those of you poo pooing a torch because it would look bad don't know how to use a cutting torch.
Originally posted by Stepside View PostSome things to consider in the choice etween the torch or the bandsaw. 1) Slower to cut but very little time to debur/clean-up 2) No HAZ on the leftover stock. 3) Electricity is cheaper than torch gases. 4) It is more attractive as a finished part. 5) It was good practice using the saw so when you need the skill level you are aware of what you can or cannot do.
If you have a machine that will do that cut , fine, but it doesn't have to be preferential over a torch cut.
That's just ignorant and insulting to many fine craftsmen who have been using cutting torches for years and turning out top work.
It's a step in a process, nothing more or less..
Originally posted by sid pileski View PostWow Doozer! I tend to agree with you 100%!
Now, to beat the dead horse, that’s the way I feel about my lawn!!! (Stripes and all)
Sid
ps. I love the clean band cut over the torch/plasma.
Because machinist vs. fabricator.
Never use a sheet metal screw when a machine screw will do.
I hate that people always want to do thing the quickest, cheapest way.
If it is your stuff, you want to make it nice. People that just slap things
together think they are setting the world on fire, and just to the minimum
to get things done. No pride. Like sloppy electricians and plumbers.
They think their work is buried in a wall and no one sees it, so why
be neat about it. Short cut city. Eff it, it's not mine is the modicum of the
world. You don't have to screw the other guy to make a way for yourself.
People have it all wrong. Nice neat electrical or plumbing (OR MACHINE)
work does get noticed and does get you RECOMMENDATIONS to do
other work, because neat work MEANS YOU GIVE A SHlT. It is nice to
see neat work, because if nothing else, it means the tradesman took time
on the details of the job, if the whole presentation of the job looks neat.
Does it take a little more money and time to do a neat job? Yes sure.
But it always pays dividends to have a reputation as someone who's
work looks good.
Torch cut or bandsaw cut tractor drawbar ??? A bandsaw is higher on the
scale of precision and alters the thermal properties of the steel in NO way.
It is classy to have a better cut on a part than a burned out part.
It puts pride in your ride. It shows the world that you put forth the effort and
expense to own a bandsaw in your shop because you value cut quality
over speed and sparks. It advertises your capability to do precision work.
It is a step above. Each job is a reflection of the man who did the job.
People today are quick to forget that. Get the cash and get on down the road
is most prevalent. It used to be, give them a little extra, and they will come back
the next time. Crazy thought, right ??? Well it used to be the normal.
Bandsawing a tractor drawbar represents all of the above.
Some people don't explain it like I did. Most would say, You either get it or you don't.
It is one of those values that you either live by or you don't. You don't just casually
give effort sometimes. You give it all the time. Remember the saying, if a job is worth
going, it is worth doing right ? It is a lifestyle choice. When I started my career
in high school at a lawn and garden store, I would put together implements.
Light duty fertilizers and roto tillers and stuff. When I first opened my toolbox
that first day on the job, I had a decision to make. Do I use a pair of pliers and a
Crescent wrench to do this job, or do I use a 7/16 wrench and a 7/16 socket and ratchet?
That decision point was pivotal in my career to come. I chose to leave the pliers and
Crescent wrench in the toolbox. That was 30 years ago.
-Doozer
One thing to remember: Many who see your work won't have a clue if it meets the technical requirements. However, most will know whether it looks good or not.
Thanks Guys,I will leave the French Bread discussion for another time lol!. Tiers mentioned the small blade,the .035 thickness is the ticket for a 3/8” blade which keeps me buying the Doall blades as I’ve tried other brands that are .025 and are very flimsy in comparison.BF was wondering about torching the plate which have done numerous times in past with decent success,what I’ve found since having a Vertical with power feed is I can have the job half done by the time heavy plate cools enough to handle.I enjoy designing and fabrication but very slow at it,better doing it in off season.I’m kinda scrambling with this project as it was not planned till last week as Nitrogen Dry Fertilizer Prices are nearly 40% higher than NH3.Took a 8 hr drive to Saskatchewan last week and purchased this Used 52’ Cultivator that’s set up for NH3,it arrived Tuesday night just before dark as Semi Hauled it accompanied with Pilot Truck as was 26’ wide folded up for transport.
Here a couple pics of Drawbar ready for welding,the one on edge shows my weaving a bit with the cut lol!
TTT doesn't have a home shop. He has a very well equipped farm shop. Because of TTT's fabrication skills I bet he is pretty good with a torch. I could cut that with a torch and hit it on the belt grinder or big disk grinder in TTT's case and you would not know the difference between it being cut on the bandsaw. Pride in the work doesn't have anything to do with my question.
Sarge41
Originally posted by Doozer View PostI have cut French bread for dinner guests on my DoAll bandsaw.
Any excuse to use it is a good one.
-Doozer
Nice work TTT, sometimes taking a little longer on one step (the cut) saves you a bunch of time on a later one (finishing)
Originally posted by Sparky_NY View Post
Cheap bastard, buy some fresh bread and you won't need the bandsaw
crisp outside/tender inside
- Likes 1
