Machining Bismuth?
  • Machining Bismuth?
    Any one do it? Really brittle crystal like stuff! Cast to near finished size. Any tips or tricks welcome!
    Almost seems like grinding “might “ be a better plan than trying to cut it.
    Im going to say grinding.
    I know it's none of my bismuth, but what are you doing?
      Oregon, USA
        Originally posted by no704 View Post
        Any one do it?
        Never tried to machine bismuth, but even grinding wants to tear out little crystals here and there.
          It has such a low melting point, I wonder if there is a more plastic state suitable for machining that could be attained with a temperature controlled flood. Sort of the reverse of 'coolant'? I'd imagine if such existed it would require very careful temperature selection and control.
          Southwest Utah
            Agree it melts at 520f. Used in cerrobend. Can you pour mould it instead of machining it?
              The 'flood' I mentioned above might be as simple as a temp-controlled air blast.
              Southwest Utah
                I did cast it near to finish size. Need to cut off the spruces and clean it up.
                  Something like that- I'd think you'd want to use a shearing action to machine it.
                    I didnt see any pics, thats my computers fualt..
                    Folks here have poo-poed on my liking of ball end mills.
                    I have them in solid carbide, Garr, SGS and all the rest. Razor sharp. If the flashing is all you are looking to remove I would concider a nice round nose bit. If it is some finishing contouring of the part I say the same. Find a good bit.
                    You might be suprised and be careful. A nice ball nose will still slice you. JR
                      It is called a “sprue “, autocorrect may have gotten you!
                        Straight from the Atomic Energy Commission: https://www.osti.gov/servlets/purl/4284913-rIhXLE/
                        Bismuth, Tantalum, and Uranium too.
                          Originally posted by deltaenterprizes View Post
                          Military is called a “sprue “, autocorrect may have gotten you!
                          Yep! Dammed autocorrects
                            Originally posted by genea View Post
                            Straight from the Atomic Energy Commission: . . .Bismuth, Tantalum, and Uranium too.
                            That was interesting. Thanks!
                            Southwest Utah
                              That was an good article. Up until I saw stellite in the mix? Kind of out of place in my opinion.. JR
                              https://pubchem.ncbi.nlm.nih.gov/periodic-table/
                              P.S. OSTI. Editor in need Ill take the Job). I only say that because they are a Univerxity based ORG.
                              "bstract
                              Techniqnes are presented which are applicable in machining materinls such as U, graphite, Ti, Zr, Th, Ta, Be, Bi, Li, and stellite.
