What do I have here?--Electric
  • #31
    Originally posted by darryl View Post
    The oddball stuff in the box has to do with the limits and the reversing. Unless you intend to use it as a bi-directional, you can toss that stuff. By the way, the transformer is to generate a small DC voltage to run the electronics to sense the remote signal. It has nothing to do with the motor. And it is continuous duty, so you could probably use it to run a circle light for a mill, or some other led lighting module- perhaps a room light that's always on, so you don't have to feel your way in the dark to find a light switch for example.
    You always have the option of adding a fan to the motor if need be. Just make something like JRouche did for one of his engines.
    Then do you know why there is a (yellow) wire between the transformer and the motor?
    • #32
      Maybe it saved a wire and connection to common them up.
      2730
