3D printed pipe miter pattern
The big engineering company where I grew up had a marine division. They did both rectangular and triangular cross section tubular booms for off-loading bulk material handling vessels such as grain, coal, etcetera. This was all pre computer, and the cut-templates were all designed by hand and then cut from cardboard manually. I never worked in the marine division, but the guys who did were very, very smart. ----BrianBrian Rupnow
Design engineer
Barrie, Ontario, Canada
Originally posted by deltap View PostThere are books on sheet metal pattern drafting that show how it is done manually.
For those of us who don't have a 3D printer this software works very well. I've used it quite a few times and
the templates it creates are very accurate. Really great for odd angle joints. For making joints in larger pipes
if you don't have a printer or plotter that produces larger drawings the software will produce multiple page
drawings that have register marks so you can overlap them accurately...
http://www.harderwoods.com/pipetemplate.phpKeith
__________________________
