Question??
  • Question??
    Hello all I just got a new monitor for my computer. 17 inch flat panel. Works beautifully except on HSM BBS the print is so small Icant read it. The others especially Practical are much larger print and readable to my tired old eyes. What do i do? I am NOT acomputer whiz but I can turn it off and on (usually). JIM
    jim
    Up at the top left of screen you should see "File Edit View Fav......". clik on 'View' and that'll show you an option for text size, which permits selecting a larger text.
    (at least it's that way for MS I.E.)
    Lynn (Huntsville, AL)
      Try this: Hold your Ctrl key down while spinning your mouse wheel toward you. Now spin it away from you while still holding down the Ctrl key.
      Same can be done with Ctrl and the + and - keys.
        Thanks Lynnl & Schutzhund, I have gotten it a little larger now. Thanks again. JIM
        jim
