Flange thickness of this Collet Chuck needed
  • Flange thickness of this Collet Chuck needed
    Can anyone take a wild guess at or even calculate an accurate measurement of the flange thickness on this Collet Chuck?
    Will email them and ask, but hoping for a quick answer here.
    Nev.
    Looks like 10mm going from their drawing.
    'It may not always be the best policy to do what is best technically, but those responsible for policy can never form a right judgement without knowledge of what is right technically' - 'Dutch' Kindelberger
      This one looks identical and has more dimensions: https://www.aliexpress.com/item/33051718913.html
        Hah! 10mm, just what I thought.
          I do not see a dimension on the flange on either web site. They both show the nut as 25mm high and the flange appears to be over half of that height so I would Guess-timate around 15mm.
            Second drawing: 25 – 15 = 10
              Yep.
                Thank you. Never even saw that 15mm dimension till now.
                Nev.
                  Sorry, I did not see that one.
                    Have ordered one of these from AliExpress for my Toyo ML-1. Register depth is 6mm where I need 7mm but I'll find a way to fix that somehow. PCD and Register Bore should be perfect.
                    Nev.
                      Like
                      Ohyeak yeah. Does 10MM have to do with anything? JR
                      P.s. like even the pull socket in the center. 10mm is what? Close to a half inch?
                      Yes, I have some odd ball tool holders. Need help let me know. JR
                        Yes.. Richard and Tomatoe Soup got it on the nose. In my opnion. JR
                          A tomato does not have any toes.
                          Nev.
                            Hahaa. Potato, tomato kinda thing . JR
