Hi everyone. This might be a stupid question but I am a little stumped. I have AXA style tool holders for my QCTP on my lathe. Most of my tools are 1/2" shank and fit nicely. I am able to adjust the height adjuster screw to center it on my work piece and then lock it down so it stays perfect for "quick changes" as the name says.
The issue is when I use a 3/8" shank tool, the height adjuster bottoms out before the tool is at the center line.
Is there a common trick to fixing this? The only idea I have is to put a 1/8" shim under the tool in the holder, but would have to make something and I am concerned about how solid it will be.
So far I have been using a spacer underneath the height adjuster when installing the tool but it's clunky.
Thanks!!
Thanks!!
