Originally posted by The Metal Butcher
View Post
The way I see it if you have to shim up a "system" the larger the contact area the better.
So some tool blocks might have more horizontal surface to shim from. Better load distribution.
If you do (shim) the tool or cutter holder that will be a much smaller surface area. More deflection, more poor cuts, more chatter, more chipping of tool tips. And more importantly? More diaper (shim under tool) changes for various jobs. I always fix the machine then the tool. JR
