Horizontal Air Cooled Engine
  • Horizontal Air Cooled Engine
    Yesterday I finished designing a welding fixture for one of my old customers. Earlier this week I redesigned one of the cylinder heads for my opposed twin engine, seeing how I could relocate the sparkplug up near the top of the cylinder head. I don't really want to mess with a finished engine, so I decided to design a new engine to go with my redesigned cylinder head today. Of course this leads me right down the garden path, and seven or eight hours after I think of it, I've designed it. This engine will be air cooled, and will have two valves and a throttled carburetor. I've put a 2" diameter fan on it, and even designed a fancy fan shroud to support and guard the fan blades. I'm not sure when I will get around to building this one, but winters coming and I will need something to do----
    Design engineer
    Barrie, Ontario, Canada
    And a couple more views so you can see where this one is going---
    Design engineer
      Today I made the first part for this engine, the cylinder mounting plate. I used my new bandsaw, and what a wonderful bandsaw it is. It zipped thru the aluminum as if it was butter. This is the first part I have made using the new bandsaw, and all I can say is, I wish I'd bought it ten years ago!!!
      Design engineer
        People on another forum commented on how ugly that carb arrangement was. The more I looked at it the uglier it looked. I haven't built anything on the head yet, so I was able to go in and change it---carb comes straight out the side now. I left that big air horn that was on the front of the carburetor off too.
        Design engineer
          Good morning Brian. Looking pretty good so far. I noticed one thing. How are you going to get the belt on the fan pulley ? Maybe the fan guard bolts together.
          Larry - west coast of Canada
            The gear ratio "LOOKS" more than 2:1 . May just be my eyes. :-)
            ...lew...
              The gears have 20 and 40 teeth. Getting the belt on will be a trick.--That fan design is just a quicky, it will have a bolt on fan support strap when I get to it.---Brian
              Design engineer
                Today was spent making sideplates. They are finished except for tapping a bunch of holes. I have used up my entire day machining these parts, and will do the tapping tomorrow.
                Design engineer
                  I had a stroke of good luck this morning. After tapping something like 20 holes, and assembling things, I discovered a length of 01 steel with two cams cut on it. The last time I set up to cut cams I decided to cut over-length while I was in the set-up for use on a potential future engine. The future has arrived!!!
                  Design engineer
                    --I picked up my cast iron today to make the cylinder. The only material that my supplier had in stock was 2.1" diameter ($25 for 4"). I haven't made the cylinder yet, but this gave me an idea. Without changing anything, I can make it look like this if I want to. This shape harkens back to some of the early model two cycle airplane engines that were made in the 1930's to 1950's. I kind of like it.
                    Design engineer
                      You ordered the book "Model petrol engines: their design, construction and use" from Amazon. Westbury advises (on p.168) fins on the cylinder head, which is prone to overheating. Fins on the cylinder are not so important on a small engine.
                      Allan Ostling
                      Phoenix, Arizona
                        Thanks for the smile Brian. I know you said you'd need something for a winter project, and now you're already building it. You are the model engine man. So- what are you going to do for a winter project?
                          One would think it depends a lot on the orientation of the cylinder no? Yeah a lot of heat would propagate through the head, but less so in a horizontal than a vertical? I wonder how much of an effect that would have.
                          And I agree with Darryl. This isn't a "winter project" You'll have this done and running before the now flies .
                            Much of the heat is from the exhaust which flows through the head, plus much of the cylinder has hot gas in it for only a very short time. The head sees it all the time it exists. (for 4 cycle engines, 2 stroke may exhaust out the cylinder wall).
                            Temperature of the head is not much affected by position, unless that affects cooling..
                            2730
                              This morning I made up the main baseplate. This plate has an interesting feature in it. In order to keep everything small, a scallop was cut from the baseplate to clear the 40 tooth cam gear.
                              Design engineer
