Sounds like a questionable spark plug, that is not firing under compression. a spark tester seems to be in order.
Why not get a thick piece of lexan or similar clear material, get one of your heads, plug the valves, install lexan window in lieu of cylinder.
In lieu on one plugged valve install air fitting for compressed air.
Get ignition going from your starter drill you can see the spark in the window, then apply shop air and determine if spark fails under compressed air
Compression test: can you use soapy water & run engine with drill starter and get soap bubble around head gasket??
