Very classy given the look of the rest of the engine. And as you say, you can always alter it if you don't like it.
Horizontal Air Cooled Engine
I lke the new flywheel idea a Lot! It keeps the "design element" of spokes, but reverses them, and looks pretty darn good in my opinion.
Great idea, and definitely easier to machine!CNC machines only go through the motions.
Today was intake and exhaust day. I had just enough brass around the shop to make these two assemblies. I have to go buy some more 1/2" diameter brass rod to make tappet guides and valve cages with. All or at least most of the brass will get polished as I get deeper into this engine.
Design engineer
Barrie, Ontario, Canada
- Likes 1
Originally posted by brian Rupnow View PostRichard--I'm not sure what you mean by "a small faceplate casting". Anything round and at least a 1/2" thick will work. Don't use aluminum because by itself it's too light to make an entire flywheel from.
'It may not always be the best policy to do what is best technically, but those responsible for policy can never form a right judgement without knowledge of what is right technically' - 'Dutch' Kindelberger
The morning was spent cutting out the centers of the brass flywheels on the old Rupnow Engine to give me two nice outer rims for my new flywheels, and cutting two aluminum centers from a piece of 3 1/2" diameter aluminum that I had left over from another project. I still have miles to go before I sleep, but so far things are looking good.
Design engineer
Today I did something for the very first time!!! Those reliefs in the face of each flywheel are 3/16" deep, and they have a 1/8" radius in the corners. I have always known that there should be radius there. I know the whole tune about sharp inside corners causing stress risers and are more apt to fracture in use. It's just that I never actually did it before. I have about 40 engines running just fine without a radius in the corners of the flywheels. Today I actually ground an HSS tool and machined the radius. The outer brass rims are loctited to the inner aluminum flywheel body (That's why they look dirty--that dirt will all come off with a "clean up" pass in the lathe.) Drilling and reaming the center hole for the shaft is one of the last things I will do.
Design engineer
- Likes 1
Which is it? You say that to get the flywheels to run true the centre hole would normally be first. Then you say that doing the centre hole first is just asking for trouble.
Anyway, my usual practice with flywheels is to face one side and the edge at one setting, finishing by doing the bore, then flip over and face the other side. I don't like doing flywheels on mandrels, they are usually quite large and the mandrel to fit the bore relatively slender. I haven't had any problems with run out doing it this way.'It may not always be the best policy to do what is best technically, but those responsible for policy can never form a right judgement without knowledge of what is right technically' - 'Dutch' Kindelberger
Originally posted by Richard P Wilson View PostWhich is it? You say that to get the flywheels to run true the centre hole would normally be first. Then you say that doing the centre hole first is just asking for trouble.
The flywheels are finished except for keyways, and I like this new variation on round holes cut in the webs. This gives the flywheels an interesting look, and it will still make it highly visible when they are rotating under power.
Design engineer
- Likes 5
I think they look quite spiffy!CNC machines only go through the motions.
