I bought a new Miller AC buzz box back in '88, gently used. Recently I found the same model in an AC/DC version at auction. I bought it, tried it out with a few short welds. Then I sold my AC buzz box - might have been a mistake.
I was using the AC/DC welder in DC mode recently. I may have exceeded the duty cycle but there were definitive pauses between welds. Machine welded fine. Note images w/ cables shows how the leads were connected. About half an hour after welding I happen to look down at the floor in front of the welding table when I spied one of the insulated "nuts" on the high AC connector (Note: I was **not** using AC). The insulated nut got hot enough to melt off of the connector. I opened up the welder, looking for a loose connection (high resistance, high heat) and all connections are tight - including the high AC where the nut melted off. How do I trouble shoot this? I don't think just turning a new nylon "nut" is adequate. When looking at the images from inside of the box, the AC high is the one with dual leads. TIA for any insight.
