How should I cut this slab of aluminum?
  • How should I cut this slab of aluminum?
    I have to cut a 14" wide (35 cm) by 3/4" thick (2 cm) slab of aluminum about 14" in from the end. This is too big for my Horrible Fright horizontal bandsaw. It's way too much for my hacksaw. I don't have a cold-cutting saw with carbide blade.
    So far my only idea involves mounting the 70" long piece of aluminum on my Bridgeport with the long direction along the Y axis, and then slot-cutting it along the X axis while I hold the wobbly end. Or I could take it to a machine shop, but I'll bet they'll charge a pretty penny...
    If I were "This Old Tony" I'd just mark it with Dykem (the blue is gone from my skin, now), scribing the line, and then allow video magic to do the cut. I am not that clever.
    A powerful circular saw with carbide tip blade. At work we had a 14 inch air drive saw. It would cut thru 3 inch 6061 like a piece of wood. If you dont want to buy a saw, take it to your local machine shop and let them saw it?
      some woodworking tools like skilsaw , circular saw, tablesaw, also work on aluminum.
      BUT, the flying chips are eye hazard, noisy ear hazard
      wear your PPE
        Yup, regular wood cutting circular saw and carbide blade will cut it.
        You could run it thought a table saw if you have one or standard chop saw from both sides should get it.
        It helps if you can keep some sort of lubricant on it, wd40 seems to work fine.
          Another vote for a circular saw. Woodworking tools actually work in aluminium just fine, just have to take a little bit more care in how you approach the cut. Make sure the piece is well secured and be prepared to catch some hot chips
            Throw it on the Bport and quit lollygagging.
            Avg. machine shop will wait till you are gone…..and then throw it on the Bport.
              If using a circular saw, a worm drive works better than a direct drive, because the blade can't bounce backward, and the motor torque is multiplied.
                LOL, no machine shop is going to put a 14” wide by 70” long bar on a Bridgeport to cut a 14” long piece off
                  Circ saw. WD40. Answer has already been said. But I predict this thread will continue on for 50 more posts.
                    Bring it on over, my Kalamazoo 8CW will handle it no problem.
                    It's all mind over matter.
                    If you don't mind, it don't matter.
                      table saw or circular saw. The challenge with a table saw is to keep the piece from skewing as you push it through the blade. The best purchase I've made in regards to cutting aluminum is a proper blade. I went with a 7-1/2 inch blade so I could use it on either saw, and for my 25$ I got one that does a beautiful job on acrylics, aluminum, plastic laminates.
                        It all depends on what you have on hand for alternatives to the mill.
                        Personally I have used a table saw, a hand held circular saw, and a sawzall for similar cuts, the Bport slot cut would be my last choice.
                        Use plenty of lube, I used WD40 because that's what I hand on hand, worked great.
                          Table saw with a rip fence rather than a hand held circular saw if you care about a straight edge. I also use WD40 when cutting aluminum. If you use a smaller diameter blade than your table saw is designed for (say 7-1/2 vs 10 or 12 in.), the effective cutting speed will be lower, which may be a good thing - but you do want carbide teeth in any case.
                            [/QUOTE]
                            So, the fear of the emergency room has passed !!!!!!
                            Oregon, USA
                              Bull! I always use a carbide tipped blade for cutting aluminum. For this job I would use a circular saw. Trying to make a crosscut on a table saw on that long a piece is asking for trouble. You wind up feding it crooked and binding the blade
