In my lathe, the jaws are two-pieces and bolt together. One part rubs against the scroll and has some contact area with the workpiece, and the outer part touches the workpiece only.
I found that there is a gap between the workpiece and bolt-on jaws. The gap is perfectly parallel with the work, telling me it's not wear or damage, but actually some kind of incorrect offset.
I would say the gap is .001-.002", enough to see light through, and enough to induce chatter on heavier cuts.
In aluminum, it's small enough of a gap that tightening the jaws deforms the stock and it holds fine, but in steels it does not.
Can someone shed some light on this? Is this a common thing, an if so how might I address it?
