What sort of thread inserts are called for when repairing holes tapped in aluminum castings in order to eliminate galvanic corrosion between dissimilar metals? The application is a 6M threaded boss in a cast section of an aluminum m-cycle frame.
Are inserts made of aluminum available for repairs of threaded holes in aluminum ? Or steel inserts that have been plated with copper/some other coating to provide a barrier between the steel insert and aluminum parent material?
I notice that Time-Serts designed for spark plug hole repairs are copper or silver plated (depending on seat type).
