At least on the Z, probably on the Y as well? Doesn’t seem to be all that common. Reasons for that?
DRO on a surface grinder?
Originally posted by RB211 View PostAt least on the Z, probably on the Y as well? Doesn’t seem to be all that common. Reasons for that?
There have been a few times where a readout would be handy like face grinding some step in a small shaft/pin in a harig fixture, but honestly dials are not that bad. If one really needed a better system you could setup an indicator on it to check movement, but IMO the dials on surface grinders are just fine.
- Likes 1
Z isn’t wheel height?
Originally posted by Dan Dubeau View Post
Z is almost always universally the spindle axis in the machine tool world. I say almost always as I seem to recall a specific example presented years ago on PM where Z was some other axis on some machine tool, but I can't specifically remember what it was.
So on a lathe, the spindle is Z, and the crosslide would be X?
The last shop I worked in had two grinders with DROs. They were both Mitsui grinders and were only used dry. We did a lot of small, intricate stuff in steel and graphite and the DROs were really handy.
George
Traverse City, MI
- Likes 1
So I guess for an HBM your table is Z and X. You head would be Y. Spindle C. Table rotation... B?
Originally posted by The Metal Butcher View Post
Interesting. Had me tripped up too. I wasn't aware.
Horizontal mills,
Horizontal boring mills,
Horizontal lathes,
all the same.
They all have the spindle horizontal.
Hence the naming convention.
Z is always the direction the spindle is pointing
no matter what the machine.
I have a machine tool design college textbook
as thick as a telephone book (remember them)??
and it shows the axis very clear.
-DDZER
- Likes 1
On our 5 axis Horizontal Boring Mill really 6 Axis, but only ( any) 5 simultaneous
Spindle in/out = Z
Headstock Up/D= Y
Table In/Out = W
Table L/R = X
Table Rotate = C
Index Head R/T = A
Rich
Edit, You can see that both W and Z can move the same direction
That is like on a Bridgeport- either lowering the quill or raising the knee
In our case. the Spindle could move 32 inches, but the Table could move 6 feet.
(Mill weighed 80,000 # )Last edited by Rich Carlstedt; 11-10-2021, 08:00 PM.Green Bay, WI
- Likes 1
