What I have is an TH6580WF, what they call a 7 day programmable WIFI thermostat. It has remote access etc , etc. But they never tell you if it stays programmed through a power failure.
I have it sitting right here ready to install in a property we are only at intermittently, and I'm at it now. It's cold here, and we want to remotely see how the temperature is, since it has radiators, and I have not put in any antifreeze.... besides, there is the regular water system also.
Anyway..... I want to be sure this thing does not forget all it knows if the power goes out. It does not have any apparent battery backup, so unless it has NVRAM somewhere, it will.
If anyone has put one in and knows about that, I'd sure like to know before I install and program the thing.
It seems as if it would be incredibly stupid to have a thermostat that goes back to "new puppy mode" if power hiccups, but I do not KNOW that this does or not. The whole point of the matter is to keep an eye on the place as to temperature inside while we are not there. So if it is dumped back to unprogrammed condition if power drops out, that is not so good, and I'll just return the POS unopened.
The instructions (read online) indicate that if you mess up when programming, to just unplug it from the backplate and then reconnect after 10 seconds. That seems suspiciously like the ordinary power line reset, and may indicate that it does utterly forget everything if power goes out. Or not. Nothing in the FAQ, nothing comes up in searching their help info. Live chat is "not available right now".
