I have a Sieg type mini lathe and a mill (SC3 and SX2P brushless DC), and I realized that I will be very likely facing a belt change soon. To be honest, I'm surprised I haven't had issues with them yet, because I have never machined anything else but steel with them. Thinking of changing the bearings at the same run and having some interest in improving the machinery, I thought about different belts - and chains. Since for example bike parts and chains are readily available everywhere, turning a mounts for them for the spindle and motor could actually be rather doable. Apart from availability, the gear ratio could be readily changed, the chain length can be adjusted freely to any size by re-linking it, and it is mechanically likely stronger than any other part of these toy machines. (Which is of course a little issue, as something else will give up if they are crashed, but mine just trip if they are overloaded)
So, is this a completely dead-born idea, or has someone actually done this?
