Originally posted by Frugalguido
View Post
1/12 Scale Cat D11 Bulldozer project
Originally posted by sid pileski View PostQuestion: In the last pic, what are we looking at cost wise?
(Of the hydraulic components)
Thanks, Sid
Each hydraulic cylinder was $24, the filter was $24 I think. Each track pad I printed used .17 cents in material.
RB, What are you planning to do on making the links and the track pads ?
One method : Print them all with your 3 D Printer and send to Shape ways for metal castings ( SS?) ( hint combine the pieces ....like six parts on one stick to reduce cost)
Second method: Make a die (S) and hot forge them just like the originals were made
Third method: Machine them from solid : Ugg
Rich
Green Bay, WI
RB- correct me if I'm wrong, but the track pads look to be disproportionate to the other components.
For instance, the filter is larger than the track pads.
I realize that you are at the mercy of what is readily available. Also, component like that will be buried in the chassis.
Not being critical, as I know you are in the beginning stages of design.
Another thought for the track components; those shapes lend themselves to the extrusion process.
The cost of the die is obviously the big expense.
I wonder if once you are far enough on the design, you could get others to be interested in building one too.
Tracks are not limited to dozers.
I think it would be like the early days of extruded rail. Someone had to make the initial investment, then started selling the stuff.
I hate to say it but, I'll bet you could find an off shore extrusion place to make the die(s) and run the material.
Then your just looing at second ops to cut to length drill, C'sink the pads, cut to length the links, drill/ream.
Hell, you could offer muck pads (high flotation?? whatever they call them).
Sid
I'm almost sure RB211 has already seen these from Aliexpress and they aren't cheap, 20 USD+10.85 shipping for the pair. Could get expensive real fast!
https://www.aliexpress.com/item/32548895604.html
Better yet is
https://www.aliexpress.com/item/1005...014.2.24225810
But the problem is the scale is 1/14, not 1/12
Rich
edit ---was better linkLast edited by Rich Carlstedt; 11-29-2021, 08:10 PM.Green Bay, WI
Originally posted by RB211 View PostThere's a lot of cool stuff up on Aliexpress that my teenage self would of gone crazy for.'It may not always be the best policy to do what is best technically, but those responsible for policy can never form a right judgement without knowledge of what is right technically' - 'Dutch' Kindelberger
- Likes 1
Originally posted by A.K. Boomer View Post
Do roller chain bushing rotate? why yes that's what gives them the name "roller chain" --- used on my bicycle and in car engines and without them the engine would disintegrate in short order as well as my bike drivetrain...
Originally posted by tom_d View Post
On some dozer applications placed in severe service the undercarriage may have what the industry calls a S.A.L.T. track. Sealed And Lubricated Track, the pins run in oil with O ring seals. Long lasting, and of course priced accordingly.
Oh Oh Oh, With those miniature hydraulics I could build a scale model sheep shearing machine but use mice instead of sheep! Does anyone know if there are hairy mice?Location: The Black Forest in Germany
