Suspenders in the Shop !!!
  • #46
    Originally posted by RancherBill View Post
    Get an Elastic belt. I had your problem, started with suspenders and then evolved to Elastic Belts. They expand and contract as you move around or get up and down and keep your pants in place, They do "wear out" as the elasticity decreases so you need to change every 6 months.
    I would think with the cheap skate nature of most of the guys here
    that a bungee cord around their waist would be better received.
    -Doozer
    DZER
    • #47
      -Doozer
      Maybe they should we 2 bungee cords put them over their shoulders and hook them to their belt loops and call them suspenders
      • #48
        One thousand percent yeah! ! ! !
        --Doozer
        DZER
        • #49
          I have to wear ball suspenders --- but they are more of an undergarment, so no loose straps or anything and can't get caught in any of the machinery that I run....
          • #50
            Oh, Boomer, you left yourself wide open on that one
            Oregon, USA
            • #51
              only if machinery ever did get ahold of one of the straps ---
              • #52
                Sounds like you should watch this PSA...
                • #53
                  -Doozer
                  For them, buying pants that fit properly is out of the question.
                  Similar to the geezers you see at fleamarkets, swap meets, estate sales, wearing their old suit pants with some dirty shirt, because the pants aren't worn out yet..
                  • #54
                    It just goes to show you - just when you think you got it difficult there's always someone out there that has it worse - always something to be grateful for...
                    • #55
                      First of all, NEVER use clipon suspenders. Always either rivet on buttons or use the type of suspenders that have loops for your belt. The suspenders hold up your belt and the belt holds up the pants.
                      If the actual problem is the snaps catching because they stick out, then get the belt loop type. These are the belt loop type suspenders I use:
                      https://welchworkwear.com/in-3800.html
                      metalmagpie
                      • #56
                        I just did a stupid thing. The nice Amazon driver dropped off a nice new R8 shank 1.25" three cutter end mill. Of course I had to try it. I was three surfaces into squaring off a hunk of rusty block when I realized I was wearing a sweater that loves to hold the curly little chips.
                        I know it's not suspenders hooking on handles (I admit to laughing a bit at the "sudden reversal" ) but it's still annoying....... ESPECIALLY since I've been thinking for over a year now that a shop apron would be a very nice thing to start using....
                        So.... heavy cotton denim like cloth or thin leather? And if leather smooth "patent" or is suede OK? Which works best in a metal shop?
                        Chilliwack BC, Canada
                        • #57
                          Im assuming your talking for ball suspenders? dude u got to go with cotton no if's and or buts about it --- first off - if you have this particular problem to begin with to where you have to add support you also got to let the boys breathe - it's just as important as supporting them... no leather or suede --- unless you like being uncomfortable while walking around the shop stinking and have already had all the kids you want...
                          • #58
                            ... I'll just sit back and wait for the emergency train crew to arrive and see if there are any survivors from this violent de-railment.....
                            I was referring to options for a shop APRON......
                            • #59
                              oh Apron,,, go with anything but polyester or terry cloth lol
                              • #60
                                I got my $15 suspenders from Etsy and as soon as I bent over, the back clip broke. It was just sheet metal and rather cheaply made. I hope to get at least a partial refund. I fixed them sort of by replacing the clip with a key ring through the rear belt loop of my pants. Meanwhile I've found much better suspenders, but at least I can get an idea of how well they might work with these.
ID:	1999773 Click image for larger version
                                USA Maryland 21030
