The fuel injection pump on my backhoe ate itself so I started cleaning all the muck and grime with engine degreaser and a pressure washer I got for free from 3PhaseLightBulb. It's like an 1800 psi, low volume pressure washer but works fine for basic tasks like this.
Then I saw Mr. Fixit's post in the thread about wet sand blasting kits for pressure washers, something I thought about a few years ago, but those kits require a minimum of 3000 psi / 4 gpm pressure washer.
So now I'm thinking about upgrading my pressure washer and then adding a wet sand blast kit for removing paint and a hot water conversion kit for steam cleaning greasy / oily things.
Trouble is, I don't know who makes a good pressure washer these days. All of the product reviews I've seen are based on "homeowner" pressures washers (1800 psi, battery operated, etc.). What would you guys recommend? I see DeWalt makes a 3500 psi 4 gpm gas powered unit that was expensive but not way out of the question. Many of the truly commercial ones seem to be >>$1k, and that's too steep for how often I would use it.
