Mystery hole in drill bit
It's for free drilling by hand --- it's a strategic failpoint where the drill will snap off so as to not "spoil the work" as you will usually not be drilling that deep and can react in time, actually came about when working with mahogany and teak as it's a little pricey to have a "joe fudded up moment" then metal workers started using the practice about the time Dooze started using machinery...
Thanks Doozer, I googled bell hangers drill and found this: "Bell-hanger drill bits are long bits that make holes through walls, studs, flooring, and other surfaces so wires can be pulled through these surfaces for hooking up televisions, telephones, alarm systems, computer networks, and other equipment."
Proves your never too old to learn something new
Oregon Coast
I guess after feeding the wire through you would have another guy at on the other side pulling the wire tight as you put the drill in reverse slow mo --- that would keep it inside the flutes and keep it from getting severed on the way back out the other side....
Hey - if it's for pulling wire back through then why would you not have the hole more towards the end of the bit ?Last edited by A.K. Boomer; 11-17-2021, 06:34 PM.
A.K. Boomer, when I looked up information about the bits they showed 12" (like mine) 18" and 24" long.. I guess you would need a whole set if you was in that sort of business .. I don't even know where I got mine. I buy tools all the time at yard sales, must have been something I just couldn't go home without. I have a lot of long drill bits from 3/16 to 5/8" and this one was the only one with a hole in it._____________________________________________
Oregon Coast
And here I was going to suggest you check your tool box for Drill Termites..."A machinist's (WHAP!) best friend (WHAP! WHAP!) is his hammer. (WHAP!)" - Fred Tanner, foreman, Lunenburg Foundry and Engineering machine shop, circa 1979
- Likes 2
Originally posted by A.K. Boomer View PostIt's for free drilling by hand --- it's a strategic failpoint where the drill will snap off so as to not "spoil the work" as you will usually not be drilling that deep and can react in time, actually came about when working with mahogany and teak as it's a little pricey to have a "joe fudded up moment" then metal workers started using the practice about the time Dooze started using machinery...
JL.....
I used to use those (occasionally pulled wire for the phone company). You drill through your hollow wall or whatever, then run one strand of your CAT5 wire through the hole, then pull the wire through the hole when you withdraw the bit.
-jsThere are no stupid questions. But there are lots of stupid answers. This is the internet.
Originally posted by A.K. Boomer View PostWell I guess were not seeing Lug's full pic on it - maybe it's way longer and im just assuming it's half way up the bit thinking it's a regular sized bit... ?
