I have an AMT model 4230-97 coolant pump http://amtpumps.com/site/wp-content/...01/CLT-3-4.pdf. I looked up the specs on line, and it recommends a maximum viscosity of 900SSU. I know nothing of viscosity values other than what I read on a motor oil bottle. I found a conversion chart, the 90SSU is equal to 180cSt. I then found a website for motor oils, and that chart https://bobistheoilguy.com/viscosity-charts/ appears to show 180cSt to be about a 40W oil.
Can someone verify or correct what I am reading? My reason is, up till now I have been using a strong ratio of Rustlick ws5050, meaning a gallon of ws5050 with a couple quarts of water for through barrel reaming. What I would like to switch to is a light cutting oil mixed with some ATF, but want to be sure the pump will pump it.
