restoring and painting air cooled engine cylinders and other engine components
  • #16
    THIS ^^^^^^^^^^^^^^^^^^^^^^^^. Dry ice will just turn into CO2 gas and leave nothing stuck or hidden in places to do harm. Also, as said above, if this engine is ever going to see air service again, check with an A&P mechanic for what can and can not be done and/or used.
    Robin
    Happily working on my second million Gave up on the first
    • #17
      Good idea! I have a customer that sells dry ice blasters for HV maintenance. Going to give him a ring tomorrow!
      Otherwise I am just going to wire brush it for now and call it good enough.
      Jon
      • #18
        The reason you see black cylinders ( and heads ) is that black dissipates more heat than any other color ( Radiant !) hands down !
        I amazes me to see air compressors or other machines with fins for cooling and they are green,blue, or silver ..
        So if color is required, use black, or black, or just black
        Rich
        Green Bay, WI
        • #19
          So true, the color black does have an uncanny ability to to both transmit and absorb infrared energy, no argument there, black is thermal radiation's friend.
          One has to ask the question though as to why almost all air cooled aircraft engines, while often wearing black cylinders, will more than likely use as cast and unfinished aluminum cylinder heads. The greatest amount of heat on any valve-in-head internal combustion engine originates from the cylinder head, not the cylinder.
          Large radial engines usually incorporate the cylinder and head as one unit and most are in the white also.
          I'm thinking that the greatest amount of heat is transmitted through convection and not radiation and the paint acts like somewhat of a barrier.
          Click image for larger version  Name:	QBU3VBS6Q7meJOw2w2R4yx5JFVGdW4-KLpc3YJsN4teejslnEI4RV2HGVgg_5la1-rBOEqF0JgQ8Hsp2eDUbY3uYS4_WEgahWSyMgp3VPDtjKw0y8qbFHJS5Qpdbx5GFkJKo_ERGJpV9ILMzfvYLg2QQuQ0cEz1qG9vo1Ph-lE84EzQJ5gcum5NlTEqO-KQ5Y2Qrzx7C-yogN3Bro1EL2cLocaTTx1W-EodyEkK-o2K1A8MfCLWEPuWDq2qrsCY Views:	13 Size:	74.4 KB ID:	1971602
          Click image for larger version  Name:	TSIO-520-R.jpg Views:	12 Size:	642.5 KB ID:	1971603
          • #20
            The cylinder and head on mine are one piece too, Willy. I wonder if they dont paint the head portion just because nothing lasts with the heat, like exhausts.
            Jon
            • #21
              I see my customer even offers a service for aviation!
              https://www.coldjet.com/dry-ice-blas...pace-aviation/
              Jon
              • #22
                Yep, inside the cowling, there is noplace for heat to radiate TO. It's all ram air forced convection, which is far more effective anyhow. It's the same with electronics and heatsinks.
                2730
                • #23
                  You have kids right? This sounds like a case for child labour If there ever was one . Small hands, small wire brush, and some leftover halloween candy....
                  • #24
                    Dan, I like the way you think!!
                    jon
