Originally posted by oxford
View Post
In my case the end mills I'm using as boring bars are those which were badly dulled or chipped from use in the mill. I've got no way to sharpen them for further use as end mills. So regrinding them to serves now as single tooth end mills means that they can't be flipped over any longer either. But for those that might use a new end mill for boring the square holder is a pretty nice idea.
But perhaps not so easy for many of the 4 way posts found on the mid and smaller size lathes. Here's why....
4way posts have fixed height slots where the center height of the lathe axis is above the center of the slot so it can line up with the intended square shank cutting tools. In my case (I just checked) the 11/16 (.69") has roughly .16" between my tool height setting spacer and the top of the slot of my old 4way. So in my case I'd be limited to use of an end mill with only a 1/4" shank installed in a holding block with a very high position off center hole. Anything larger would not allow me to have the cutting edge at the center height of my lathe.
This issue with the 4way, which was all I had at the time, is what led to making the shop made boring bar tool post and adapter bars seen in that previous post.
