Very nice. If I were you, I'd do whatever it takes to maintain variable speed, or at least two speed. That's extremely useful for a belt grinder.
New to me Belt Grinder :I Hope
Originally posted by Tundra Twin Track View PostYes the one one wheel has abrasive side on it,talked to Nexus Belt Grinder Guy and he has one configuration that does that with no issues.Machine is 1983 and all coating on Wheels has separated from Aluminum Wheel,will be dropping wheels off tomorrow to be recoated.The durometer will be a guessing game possible 70,I’m open to ideas on that.
Learn about material properties to make the right choice for your custom extruded, molded or sheet project. Contact us for more information.
I've been thinking about building a couple more 1" belt grinders and trying an Aluminum wheel with a series of half depth O-ring grooves turned in the OD. I figure I could even vary the minor diameters to simulate a crown if needed.
When I look these up I see them being called belt sanders, while I keep seeing belt grinder referenced in this thread.
If this is indeed a sander are you planning on doing something to up the SFM to get into grinder territory?
I am not real familiar with belt grinders but I just recently started to think about building a 2x72 and started looking at them some.
Originally posted by Tundra Twin Track View PostOxford I mentioned in my first post these are Sanders ,that I hope to convert for Metal Grinding.One pulley combination would be 2750rpm at the 5” drive wheel,maybe that’s to fast.
Originally posted by oxford View Post
Gotcha. Is the abrasive belt direct drive off the motor or is the motor driving other pulleys.
Originally posted by true temper View PostMine turns 3,600 RPM on a 5” drive and I would be happy it it went faster. What ever you do make sure it is variable speed using a VFD.
don’t skimp on belts 3M crubitron belts WILL make you smile every time you use it.
What’s your shop voltage? I saw single phase and you had mentioned a transformer so I am guessing 240v?
That's a neat tool. I wonder for general purpose use, does the tight radius at the top accelerate belt wear, especially at the splice?
I've seen a version similar to this at auctions in the US, mostly in die shops. It is smaller and lighter duty, but intended to be more precise, with indicators to set angles, etc. I can't recall the name.
Originally posted by Noitoen View Post440 V at 60Hz is not an European used voltage so that machine must have been made for the US market. Maximum speed for an induction motor in Europe is 2980 RPM
Originally posted by Glug View PostThat's a neat tool. I wonder for general purpose use, does the tight radius at the top accelerate belt wear, especially at the splice?
Any chance the machine you seen was a Philipson,it’s the only other one I’m aware of that is similar design,made in England and very pricey.This is not a Beast of a Machine like my Max 24” Disc Grinder,but will have capabilities that are totally different.Time will tell🙂
T T can’t you over speed the motor with your VFD,some of the Guys selling Belt Grinders won’t warranty the New Bearing in those small rollers when used at high speed.This is a little different Animal as the rollers on top of Platen are less than 7/8” in dia,maybe the high speed program might be a bearing killer so to speak for this machine.
I didn’t know any better and used double or triple sealed ag bearings on my adjuster idler. It ran hot for many years but it’s getting better now.
Will be running a 1ph Motor for the time being,it’s a US built Marathon 1-1/2hp that I found at the Dump,runs glass smooth.A few more kinks to figure out for pulley mount then waiting game for Wheels to be recoated and order some Abrasive Belts.Drilled some holes in Cast Body,was surprised it was 5/8” thick🙂
