Some time back I ask questions on how to fix my compressor motor, the centripetal switch was stuck in the run position.I needed air to blow out the outside water lines for winter so I went to the compressor, took a ball peen hammer and gave the motor a good whack on the end cap. Motor started right up. Sometimes you do win!
AIr compressor problem-solution
Southwestern Ontario. CanadaTags: None
👍 3
Originally posted by loose nut View PostSome time back I ask questions on how to fix my compressor motor, the centripetal switch was stuck in the run position.I needed air to blow out the outside water lines for winter so I went to the compressor, took a ball peen hammer and gave the motor a good whack on the end cap. Motor started right up. Sometimes you do win!
Whenever I had to take a BFH (big fuqing hammer) to whoop up on a porsche I always told the poor slob that owned it that some of the parts had to be gently coerced with a "kinetic improviser"
As long as you charge porsche owners about three times the price they seem to be very happy with the work...
Smackin' **** for the win. One of my favorite diagnostic methods. The secret is in knowing where to apply the smack so as to best jostle the misbehaving move-y bits on the inside.
I'd advise you still replace the switch. It was probably welded and your hammer input freed it, this time. How many cycles does it have left now?-paul
👍 1
The contacts are rough and weld together. They still need to be fixed. On one of my Chinese motors I drilled a small hole in the end bell. I unplug the motor and push the contacts apart with a wire through the hole. Got tired of bashing the motor. New switch is in order. Its on a lathe and starts and stops often, not good for a single phase motor.
👍 1
Originally posted by reggie_obe View Post
Replacing the switch too much of a stretch?The shortest distance between two points is a circle of infinite diameter.
Possibly, but since I don't use it very much it will most likely be the next guys problem.The shortest distance between two points is a circle of infinite diameter.
