Yesterday I finally grew tired of the frustrations of bump knurling. I briefly considered buying a scissor type knurler. Briefly. I've had this idea rattling around in my head, a knurler built around a Kant-twist style clamp. I have these imitation Kant-twists, they were cheap enough I didn't mine cannibalizing one.
https://www.ebay.com/itm/38342699419...AAAOSwR1FeS-at
It had to be wider than the stock clamp to accommodate the 3/8 knurling rolls, so I took it completely apart and made new pivot, spacers, nut etc. to increase the width. I also made a shank to fit the toolholder on my lathe.
This is the unit mocked up, before I riveted everything back together.
After finishing some details, I riveted it all together.
This is my first attempt, 3/4 dia. aluminum
and this is steel.
After tweaking the alignment of the rolls, this is a piece of 1/2" black pipe, turned to cleanup before knurling.
Not perfect, but not bad.
and this is steel.
