Can anyone give me some pointers on boring if I'm missing something? I've just finished a piece that was 28mm diameter aluminium with a 24mm bore through most of it and 14mm through the last bit....so it couldn't have been started from pipe. I'm eyeing up some morse taper drills to hog out future pieces but I'd like to understand if there was anything I could have been doing better.
I drilled to 12.8mm - the largest parabolic drill I have - and then bored from there. The piece was 100mm long with 74mm of that being finish piece and the rest being grip stock. The bore was 62mm deep. I had no tail support (because I was boring) and no real room for a steady rest. I was hoping to take 0.5mm DoC roughing passes with a 12mm bar and an aluminium profile CCGT insert but I found that chips seemed to build up either between the insert and the end of the bore or between the insert and the wall and either bend the bar away from the wall or move the part away from the bar. Stock was 6082T6 but just didn't want to break a chip in most conditions - had some success at low DoC finishing passes on the outside at unsettling rpm (1700+) trying to avoid screaming resonance....but wasn't comfortable trying to bore at that pace
In the end, I roughed with a tiny bar until I'd got more clearance and improved things with WD40 and some clearance by blowing air intermittently down the spindle....but it wasn't really what you'd call productive. More obstinately determined to get it done.
Any pointers that I'm going about it all wrong would be quite welcome actually
Also testimony that it's supposed to suck that much would make me feel better if that's actually the case!
