My small universal mill has powerfeeds on each axis. Also a brake on each axis. The brake is nothing more than a circular electromagnet clutch. When 24v is supplied to the brake it releases. 24v holds the brake off. I only say this because with the machine unplugged the brakes are on. I will try to retain the brakes on my intended conversion to CNC.
This mill has really big brushed DC servo motors on each axis. Each motor is about 40cm long. I have been thinking about converting this mill to CNC for a long time. It has ballscrews on all three axis and glass scales. It is a knee mill with a quill. The quill is not powered. I will use a powered knee for the Z movement for the CNC. The mill is 40 years old but in great shape. I bought it from the original owner who bought it new. Very low hours. I am thinking about replacing the motors with NEMA 42 closed loop steppers connected to a Centroid Acorn. The NEMA 42's will bolt right up to the same mounting holes for the original motors. I won't automate the spindle speeds as that is all mechanical dials changing gears. So no VFD for the spindle. I was going to go for the Centroid DCAllin1 control and keep the brushed DC servos but by the time I added encoders to the motors and went through all that it would be easier to use the closed loop steppers and have a more modern system. I will order one of the nema 42 closed loop steppers and the Acorn and connect it to the Z axis(knee) and test it to see if it has enough power. It has a 3 to1 reduction on the knee. The X and Y are direct drive to the double nut ground ballscrews.
