Making a pringle flat
Burnout? I'd like to see the plasma cutter- or laser- that can cut an inch of stainless.
(Not saying it can't be done, I'm just saying it must be huge.)
Would it have been worthwhile to tr and press it flat(er) before starting cutting? Or would that be inducing the wrong kinds of stresses? Then again, if the curvature was caused in whole or in part by the cutting, is there a risk of it re-warping as you turn some away?
Doc.Doc's Machine. (Probably not what you expect.)
Originally posted by RB211 View PostAren't you supposed to start with stock thicker than finished size?
When I pointed out to him that there is no way the part will finish at 1 inch thick he said do it anyway, so I did.
The material was 1.005-1.020" thick from the mill, this is not enough to even clear the mill surface off and maintain the desired dimension.
I do not purchase the material.
👍 1
Originally posted by Bented View PostWhen I pointed out to him that there is no way the part will finish at 1 inch thick he said do it anyway, so I did..
👍 3
Originally posted by reggie_obe View PostRTS: Rates the Same. I get paid just as much to waste my time with this material as I will when better (thicker and flater) material is purchased as a replacement.
Please let me know when you will discard the original parts in the scrap dumpster so I can retrieve them.
👍 2
Only if your employer buys such material otherwise all bets are off.
👍 2
I can't count the number of times I've told a boss "This won't work", and they say "Do it like I said". Then after it doesn't work, they want me to fix it, by reworking the steaming pile of junk, instead of starting over and doing it right to begin with. Downhill from there.Kansas City area
In my case, the boss in question was addicted to saying "you don't KNOW there will be a problem"..... Well, in many cases, yes, I DID know there would be a problem. In others, I "suspected" (strongly) that there would be a problem.
And, the problems often duly appeared in the warranty claims.
One very low cost guitar amplifier we made (in the US at the time) he wanted to get the component count as low as possible. A worthy goal, by the way.
But the resistor he wanted to remove was an input resistor in series with the input jack. We always put that in to avoid uncontrolled currents due to static electricity discharging into the input.
Well, he said "you don't KNOW that" and refused to allow the part. So, we had seasonal increases of warranty claims during the times when static was prevalent (usually winter, but sometimes during the summer A/C season). We had to put the resistor back in, and the problems magically went away.Last edited by J Tiers; 12-11-2021, 12:11 PM.CNC machines only go through the motions.
👍 1
Just in the last week, I have said aloud: "Why is there never enough time to do it right, but always enough time to do it over?"
I mean, it's not like I don't know anything --
you need to train the bosses to understand that its usually cheaper to just do the job right the first time.
In my case, they usually need it right now, but then its still sitting there 2 years later. Yes, years.25 miles north of Buffalo NY, USA
👍 5
