After a lot of work figuring out the logistics of getting a 3000lb machine moved over 200 miles away, its finally in my garage for disassembly, and cleaning.
Going to drain and flush the spindle reservoirs, and the main gear case in the head stock with mineral spirits and diesel fuel. Remove all the machine tags and work at preparing to
pull off the head stock to inspect the lead screw reverse mechanism at the bottom of the head stock gear case.
Skipd1
