Awhile I ago I put in a new kitchen. The old sink had copper running up a solid brick wall and then elbowing under the counter. I decided for my drain for the install, to tie into it the copper stub with an MJ clamp and then ABS to the sink. Going down the drain is the kitchen sink and dishwasher - No chemicals other than soaps. Soft city water. Copper would have been installed in the 50's
A leak developed some time ago, very small and at the time I assumed it was a crack the pipe coming beack from the end as all I could see was a thin line beside where the MJ ended. I fixed it by clamping a piece of silicon rubber around it. I know, I'm a bad man for not doing it properly, but its horrendously awkward to get into and the wood cabinets are there so solder made me nervous. The leak came back after a while so we started putting a bowl under the leak. (Now I am a really horrible man, but its still a bloody awkward repair and I don't squirm under sinks as easily as I used to)
Very recently, like 5:00 a.m. today making coffee, it started gushing. time to face music. Pull all the ABS and garborator out so I can get in there. Was prepared to cut out the back panel if I needed to do solder.
Took a picture, wholly crow!! I have never seen a gaping hole like that in copper . The photo is directly looking up from the bottom so it looks like the area of corrosion forms a line at where the liquid would sit along the bottom of the pipe. But its soft water only, kitchen stuff is going down the drain...I thought copper was pretty bullet proof in that situation. There is the tie in to the cast iron stack but thats a ways away. Can't think of anything else that would cause galvanic corrosion.
What do you guys think, and whats the solution? First thought is to cut past the bad section and connect there with the MJ....but the corrosion has broken through there, its like;y bad all along the bottom. We're not going to be here forever and almost for sure given whats going my nice old home will knocked down...so I'm not stiffing the next guy if a do a quick and dirty repair. Still....thinking the right way is cut out the back panel, soak all the strapping with water and desolder this corroded pipe at the elbow and replace it
thoughts? ideas?
thoughts? ideas?
