If you don't know that you are a under achiever then watch this.
Southwestern Ontario. CanadaTags: None
- Likes 2
If hes doing nuclear fission in his garage I don't think I'd want to live next door. Or even in the same state.'It may not always be the best policy to do what is best technically, but those responsible for policy can never form a right judgement without knowledge of what is right technically' - 'Dutch' Kindelberger
- Likes 1
If a 14 year old boy can build a fusion reactor in two years (yes it is limited but it is still there, was there it is in a museum now) in a garage with no resources and is basically at the same level that took physicists 60 years to achieve and billions of dollars, Ponds, Yen, Euros etc spent, you have to wonder why fusion is always 25 years away.
Originally posted by Richard P Wilson View PostIf hes doing nuclear fission in his garage I don't think I'd want to live next door. Or even in the same state.The shortest distance between two points is a circle of infinite diameter.
Originally posted by loose nut View PostIf a 14 year old boy can build a fusion reactor in two years (yes it is limited but it is still there, was there it is in a museum now) in a garage with no resources and is basically at the same level that took physicists 60 years to achieve and billions of dollars, Ponds, Yen, Euros etc spent, you have to wonder why fusion is always 25 years away.
- Likes 3
He did state that the output was less then the power input, still impressive for a 14 year old and he didn't blow up the neighbourhood. It would be interesting to know how he got away with processing his own uranium, probably for a different project.The shortest distance between two points is a circle of infinite diameter.
Originally posted by loose nut View PostHe did state that the output was less then the power input, still impressive for a 14 year old and he didn't blow up the neighbourhood. It would be interesting to know how he got away with processing his own uranium, probably for a different project.
Originally posted by loose nut View PostIf a 14 year old boy can build a fusion reactor in two years (yes it is limited but it is still there, was there it is in a museum now) in a garage with no resources and is basically at the same level that took physicists 60 years to achieve and billions of dollars, Ponds, Yen, Euros etc spent, you have to wonder why fusion is always 25 years away.Last edited by tom_d; 12-15-2021, 06:42 PM.
If you watch some other Ted takes he has done the fusion plant is the least of his accomplishments.The shortest distance between two points is a circle of infinite diameter.
I suppose one could characterize any project, such as a search for the answers to fusion, as a potential money-making scheme. If there wasn't money to be made, there wouldn't be the project. The money being made is from research funding, and there are lots of projects, such as cancer research, that are in this category. If fusion delivered on its promise of cheap and virtually limitless energy- well it becomes an oxymoron. It couldn't be cheap because all that research money would have to be paid back, with interest, and it would have to keep that money stream flowing and in ever greater amounts. That's just business as it is in the world today. We know that all our sources of electricity are being put under more and more scrutiny, and at some point the end user purchase price will be all but out of reach. At that point fusion derived power would come on-line- at a cheaper but still exorbitant cost. At that point it could start to perform. I don't think the challenges are technical anymore- one look into the drug industry will show you what drives it.
Yes, there is a lot known now about fusion, and a lot of ground work has been done. I'm not surprised that a student could come up with something like this. No disrespect meant to this guy- he is far beyond what I may have come up with at that age, or even now. Kudos to him.I seldom do anything within the scope of logical reason and calculated cost/benefit, etc- I'm following my passion-
Yeah, he is/was over on the fusor forum.
So this kind of fusion, IEC fusion, was originally invented by Philo Farnsworth (as in the TV inventor) invented in 1962. The design has not really changed since then and is actually easy to do assuming you can scrounge parts or have someone that will fund the project. There has been a few kids building these things, I think there might have been one younger than him.
The consist of a vacuum pump, a small chamber and a high voltage insulator feedthrough with a grid. It's pumped down and a little bit of deuterium is introduced into the chamber and then a negative high voltage source is applied to the grid, around 20-40kv. electrostatics cause the D2 to smash in the center and fuse and out comes the neutrons. At least that's the theory. Recently people have been studying where the fusion is actually occurring and it seems to be happening all over the interior of the chamber, so it's possible the theory of operation is all wrong.
Fusor's are not good for much. You can use the neutron flux to activate other materials like silver for doing other experiments. I did have a friend who managed to get a neutron flux high enough where it made him sick. He ended up moving the fusor out to an outbuilding and ran it remote control. There are no radioactive byproducts from this other than the neutron activation of materials. The reaction creates Helium 3 in tiny, tiny quantities.
