My Sheldon mill came with mechanical power feed: a 3-step pulley on the back end of the spindle drove a shaft running along the right side of the mill. That shaft drove a worm that could be engaged with a worm gear on the feed screw. That worm & its carrier made the conversion to DC motor drive really easy. The mechanical drive:
The carrier (1) pivots on a stud (4) in the knee. I took off the pulleys, shafting, & their mounts, keeping just the worm & its carrier. I milled the bottom of the carrier flat & parallel to the worm's shaft & tapped 2 holes:
I took a small 24v motor from an electric scooter (I think), made a bracket to hold it and made slotted gears:
(5 upload limit reached - continued)
