Paul, both of my ER11 sets are in 0.5 mm increments. I also have ER25 in 1mm increments and ER32 in 1/32" increments. Although many ER collets can be clamped down to fully utilize their increments, doing so stresses the collets and the accuracy suffers. I prefer to use 6 mm collet for a 6 mm end mill although 1/4" collet would clamp a 6 mm mill just fine. Collets are ground when the slots are not completely cut through. After grinding they are split by cut-off grinding wheels or, in smaller sizes, by wire EDM.
For a 1 mm collet the slots cannot be wider than 0.3-0.4 mm near the bore, otherwise there would be little left from the bore. Bigger collets can afford wider slots. In theory the slot width is a limiting factor as to how much you can deform a collet to clamp smaller sizes. In real life however I would like to deform the collets as little as possible for the reasons stated above.
Circuit board drills with 1/8" shanks are widely available. They are very good tools, but they are very fragile since they are usually made from carbide. You need to run them as true as possible. HSS drills are much more forgiving, but they still need a good chuck or a collet.
