You have got a better luck with the chuck and collets than me. I think I will try CTC for both chuck and collets. Maybe this time I will get a better quality.
Have you noticed that CTC precision collets do not have small sizes? It has to be a reason for that.
The problem you describe with the small collets is not actually a problem. All small sizes are done this way. A small bore does not need to go all the way, a shorter one is easier to make and it functions very well. The number of splits is also lower on small sizes because you need to preserve at least some of the bore surface. The rough bore could be a quality issue, but it also could be the burrs from slotting. You can try to clean them up.
I checked my ER-11 chuck and collets very carefully for angles, bore size, contact and runout and most of the tools were a complete garbage. Maybe Amazon sellers sell better goods?
