I've got a VFD to run the motor on my lathe and it's got a display that can be configured to show either freq in hz, motor rpm, or another rpm based on the motor rpm and a multiplier / divider, so that can be the rpm of the lathe.
I thought that sounded ok but my son has decided I need more than this as I'm getting older and not the sharpest tool in the box!!
Actually, it was me that asked my son for his input as I would like the machine rpm displayed, but there is a 3 step pulley and back gears. That's 6 ratios and the inverter does not cater for this.
What he's come up with is a little more than that.
The finished article will be a control panel and display on the housing in which the inverter will live, with a rotary control to adjust the speed, a button panel to select the ratio, and another rotary control to dial in the diameter of the work. The display will show the selected gear and ratio option, the resultant machine rpm, the work diameter and the surface speed.
I know this is all not really needed but he enjoys projects like this and who am I to say no?
