Long term project. I've wanted to convert a 4 cylinder kawasaki Z650 engine into a 6 cylinder for some time now. Something similar has been done with the Z900 / 1000 motors, Google Allan Millyard for a brilliant series of videos. What he does with a hacksaw and a BBQ are astounding.
The 900 / 1000 parts are expensive, and it results in a big heavy lump. Z650 cases & cylinders etc are cheaper, and end up more compact, still giving 100BHP. "If it can be done with a 900, it can be done with a 650" was my logic.
Then I found the snag; the 900's had pressed together built up cranks and roller bearings, just like the 2 strokes that preceded them (H1, H2). Making a 6 cylinder crank just means getting 2 normal cranks, pulling them apart and repressing the bits together, properly timed at 120 degrees.
Wnen the Z650 came along, they went for split big ends and a solid crankshaft running in shell bearings, so forget pressing anything apart. My thoughts are to make 12 crank webs from barstock, 6 crank pins and some big end pins, press them together and then MIG or TIG weld the outer ends of each pressed joint. I'll reuse some bits from an original crank, the centre main bearing pin that has an integral HyVo drive chain and cam drive chain wheels on it; cut the webs off, machine the ends and press them into new webs. Maybe also do the same with the taper that goes inside the flywheel.
All much harder than with the 900, but - I think - still do-able. All of the rest is a la Millyard.
Any recommendations of a steel to pick for the webs and the pins? It needs to be weldable. I'd like to avoid any post-welding heat treatment.
Ian
Ian
