Originally posted by mattthemuppet
View Post
Hendey 12x30 inspection, disassembly and cleaning
Originally posted by skipd1 View Post.... My next task was to flush out both the 3 speed and QCGB in the same manner as with the headstock. The Jacobs QCGB was really dirty and had a lot of swarf in the bottom of the case. The 3 speed gearbox next to it was relatively clean.
-DDZER
You're just being a pain."A machinist's (WHAP!) best friend (WHAP! WHAP!) is his hammer. (WHAP!)" - Fred Tanner, foreman, Lunenburg Foundry and Engineering machine shop, circa 1979
- Likes 1
Originally posted by skipd1 View PostI had an easy time removing the taper pins on the lead screw, so I decided to pull off the QCGB as well as the lead screw and mounts. I also removed the auto stop rod, handles and mounts.
Not sure that I will post my progress any more as there has been no participation or comments for my last two updates.
Maybe I posted this project on the wrong forum.😥
Skipd1
The 14" Hendey tiebar I cleaaned up only saw attention to worn and out of adjustment areas. It did get a flushing of the spindle bearing galleys and new seals in the DriveAll gearbox. Beyond that, it was never intended to be a working machine and aside for a few demonstrations, it sat on display in the Ag. Museum.
Keep posting your progress.
Originally posted by Fasttrack View Post
Are you going to fix that broken "front tooth" on the QCGB?
Originally posted by skipd1 View PostMaybe I posted this project on the wrong forum.😥
Skipd1
I'll try to comment more.
Good job on getting the taper pins out, I had to drill a plenty!
Cheers.
I'm with the metal butcher, Keep the progress coming as many of us have been or are in your shoes right now. I too will try and comment more but I'm in your shoes right now with 3 of my own machines tore down in various stages of refurbishing/rebuilding. Plus a customers Kondia mill head rebuild will be coming in the shop for a fast turnaround. Sometimes it's lonely out in front of the pack but hang in there.
With regard to the Norton gear box. Try not to do anything to it you don't have to do. I posted the rebuild of a Sheldon double tumbler Norton gear box a while back. I had a spare one year newer to rob parts from. I quoted $250 for the job and what a big mistake. It took me 22 hours.
Ron
it is interesting to see your progress. I wonder how you have learned about this lathe? Have you had a similar model apart before, found some manuals or internet source? Or just a matter of digging into it with wrenches and figure it out as you go?
I have certainly found some good information on projects I have done but it seems like there is a balance where sometimes it is best to get off the couch, dig into it, get your hands dirty and figure it out as you go.
Luck was on my side...
I did not have to take all the gears out of my Hendey QC box
to clean it. It has bearings, not bushings, and everything looked
just fine. I did use a bunch of lacquer thinner and a long brush
to get in there and clean all the grease. My Hendey is a T&G
lathe, and it uses grease to lubricate everything. Not my cup
of tea, but it protected everything from the elements, as before
I got the lathe, it sat outside for 4 or 5 years. Moving forward
having totally cleaned up the lathe from all the old grease, I am
using thick STP oil, like that so named, "motor honey" thick oil
in a grease gun pump affair, to pump into the Zerk fittings.
Good luck on your Hendey.
--DoozerDZER
