The apron turned out to be a pretty big project. I was quite impressed with the complexity and quality of its components. I has a lot of lubrication points and lines with a small pump that is activated with the use of the apron hand wheel and an eccentric shaft. It pumps oil up to the top of the apron to a small reservoir and also pumps up to the carriage to lubricate it as well. I used a shaft through the worm gears in the apron to lift the apron off the carriage. I fabricated a bracket that mounts to the top of the apron and attached it to an engine stand for easy access to the apron and helps with removing the back half also. I figured it would work well in installing all the components when cleaned up.
I'll post some pics when I put the apron back together.
Next is to attack the carriage and get that cleaned up and oil passages cleaned.
