Hendey 12x30 inspection, disassembly and cleaning
  • #91
    Finished up all the needle scaling on the main lathe castings and headstock. Not a lot of fun but felt great to have that portion of the refurb behind me. It was definitely finished with the War going on as there is not filler or any attempt to clean up the castings. I will put the first coat of primer on and see what I want to fill after. I also think I will leave the rolled edge of the chip tray polished up as any impact on those edges if painted will suffer quickly. Now lots of shop towels and Naphtha to prep for primer.
    Click image for larger version  Name:	IMG_2717.jpg Views:	0 Size:	822.0 KB ID:	1988295 Click image for larger version  Name:	IMG_2714.jpg Views:	0 Size:	778.2 KB ID:	1988294
    Click image for larger version  Name:	IMG_2715.jpg Views:	0 Size:	875.1 KB ID:	1988296 Click image for larger version  Name:	IMG_2716.jpg Views:	0 Size:	731.2 KB ID:	1988297
    • #92
      Worked on cleaning up the various and many brass name and info plates. Some were so covered with layers of paint that I didn't even know they were there. I tried to be patient and took quite a little time in cleaning some of them. The lube plate for the apron and the Hendey name plate I cleaned up, painted the background in black and scraped the raised lettering with a razor knife.
      The main heavy plate that shows the feeds and speeds on the quick change gear box I pretty much left alone and It had nice patina.
      Next is to start to assemble the apron and get it ready for installation.
      • #93
        I dropped the apron down off of the carriage and mounted on a jig to hold it on my engine stand. I learned this trick from someone on the practical machinist forum, which actually turned out to be a great method of positioning the apron during reassembly as well.
ID:	1990306 Click image for larger version
        I then started with the disassembly and cleaning of the components. The apron was surprisingly clean of swarf. I removed the swarf cover, split the back half off and took some pics to remember how to reassemble later.
        My parts washer was just large enough to clean all the larger castings.
ID:	1990307 Click image for larger version
        • #94
          Nice job on that. I have a 2” receiver hitch under the one work table. I made up a holder to fit into that to hold the head of my mill when I had it off, engine stand would have worked just as well.
          • #95
            After cleanup it filled and painted both castings, cleaned and polished the handles in preparation for assembly
ID:	1990444 Click image for larger version
            After painting I started to install the components back into the main apron casting.
ID:	1990447 Click image for larger version
            I didn't know there was a difference in the worm gears and quite a difficult time until I figured that out.
            • #96
              Very nicely done. You're doing a fine job, keep it up. When I did the apron on my 14 X 40 Saimp it was quite the challenge working on it on the bench then flipping it over for this and that. I can see the fixture on the engine stand would be much handier, well done.
              Ron
              • #97
                Thanks Ron, I appreciate your comments👍
                • #98
                  Love the engine stand adaptation.
                  Pretty cool.
                  I will be taking the apron apart on
                  my Hendey T&G pretty soon.
                  This is helpful.
                  -Doozer
                  DZER
                  • #99
                    Apron is finished and ready to go back on the lathe when its ready.
                    • You do very nice work.
                      Lewis Grizzard
                      • The main lathe casting, and headstock are all cleaned up and primed. I plan to a little more spot filling on the front of the headstock before final coats of finish paint. I will brush and roll on all the large sections of the casting but I will spray the headstock. Its nice to have a clean machine ready for finishing.
                        On the chip pan I polished the rolled edge as I feel the paint will only chip off and its a high wear area. I will prime and paint the chip pan last.
                        • What type of coating will you use in the chip pan that will resist oil and scrapes?
                          • skipd, yer gonna need sunglasses to run that machine.
                            • Originally posted by reggie_obe View Post
                              Nothin' except powder coat it. Maybe I'm weird, but I like seeing the wear marks, so I just let it wear.
                              • Originally posted by The Metal Butcher View Post
                                Spray in bed liner material would work, but wouldn't be very smooth. We had equipment carts powder coated, found the finish anything but abrasion resistant.
