Machined and welded up a glove warmer for an RTV I have. It allows heat from a heater vent to warm extra gloves. Pretty silly but that has never stopped me before lol.
I machined a pocket to fit an existing piece of metal by the windshield. The round pivot pin is actually milled in the rectangular piece of steel. I drilled two sort of detent positions in the round so it can either hold the gloves over the vent, or be swung 90 degrees parallel with the windshield to be out of the way. The set screw pushes on the spring which pushes on a steel ball which goes in either notch position in the round.
I did not take a picture of the holder swung to the side.
